For me is necessary the electric diagram of engine control Z5 and the procedure regulation of throttle position sensor.
1What year is your car? What engine does it have? And to understand, you are looking for the procedure for setting the throttle position sensor? – Pᴀᴜʟsᴛᴇʀ2♦ May 15 '15 at 17:28
Are you looking for an electrical diagram for your car? – DucatiKiller May 16 '15 at 3:17
I restore the automobile Mazda 323P of 1998.The electrical circuit of engine control is necessar. Engine mazda Z5-DOHC. – SERDGY May 16 '15 at 7:18
In this engine it is necessary to very accurately adjust throttle position sensor. Otherwise heavy expense of fuel… – SERDGY May 16 '15 at 7:28
I'm not sure which engine the Z5 is, but this is the procedure for the 1997 Mazda Protege engines. The Protege's are called 323's elsewhere in the world for those years. Let me know if this helps. – Pᴀᴜʟsᴛᴇʀ2♦ May 17 '15 at 12:25
