Relates to: Best way to recharge battery using alternator?
Didn’t drive car for several months and battery was less than 1 volt. As I didn’t have a battery charger rather than go out and buy one or buy a replacement battery I decided every time I make a trip I’ll just use the jump starter and ensure I’ve driven enough to restore some charge.
Took me about 6 jump starts over 3 days of driving with £60 of fuel to get it from 0 to 12 volts over 3 days of driving. I used a jump starter not jump leads so it wasn’t much hassle.
Charging via the alternator saved me from having to go to the shop and buy a new battery and remove the battery and put it on a charger for 48 hours. However I understand that this is not good for the alternator(or battery) as mentioned in the linked answer.
How significantly does it wear the alternator and how does it affect the battery as well? This is not the first time I’ve done this, but the question is how severe damage is occurring, what are the implications(it’s easier to diagnose and replace a battery than an alternator) and instead of doing what I did would it be better to have bought a new battery or just be patient and get a charger?
If what I done reduces alternator life by say 2% that’s not that bad because this doesnt happen often and the battery is usually ok. So is any damage significant enough that next time I should buy a new battery or use a battery charger?
Another thing to note is that people do this all the time due to leaving lights on etc, however in my case I guess the battery is far more depleted and one journey wasn’t enough to recharge.
Thanks
