January 2024, I replaced my driver's side headlight as the low beam was not working, but the high beam was.
Pulling the bulb out, it showed a burnt filament and I replaced the bulb no problem. However, in the end of July, the driver's side low beam stopped working again.
I pulled out the bulb, but didn't notice a burnt filament and there was no rattling of the filament in the bulb.
Doing some quick research, I'm assuming it's either a bad fuse or a faulty headlight relay. I'd like to take care of this myself, but I don't know how difficult it is to replace a fuse or headlight relay.
Has anyone seen a similar problem and how simple/cheap is the fix?
Thank you
