I'm prepping replacement rocker panels (Nor/Am Canada SKU:0897-100L) before installing the panels on my 2010 Silverado.
The panels are bare steel, so I've painted them with brush-on Tremclad Primer before painting them white. I cleaned the steel with brake parts cleaner prior to painting with primer.
It's been 48 hours since I did the painting. I've noticed that the primer is very soft; I can scratch it with my fingernail down to the bare steel.
Is that expected? Does primer dry quickly but take many days to fully harden/cure?
I ask because the soft paint isn't inspiring a lot of confidence when it comes to stone chips and salt spray. If I can scratch it with my fingernail, then stone chips will easily scratch the paint and cause rust. I know with automotive applications, paint is normally sprayed, not brushed. But I went with brushed since I thought it would be thicker and more durable, and the truck is just a beater, so aesthetics are not important (the paint won't be visible from outside of the truck). But now I'm wondering if the brush-on primer is not up to the task.
