This is my Ducati Monster 696 2012. The clutch line is discolored as you can see. I have been less than diligent in flushing my clutch fluid, so I would guess the fluid absorbed water and caused rust. I know the bike is advertised as having "steel braided cables" but I'm actually unaware of how they're configured and how to correct this.
Is the steel braided cable inside of the tubing to add rigidity, and the fluid has rust particles in it, so a couple flushes should clear it out? OR are there basically a tube within the braided line through which the fluid flows, and the seal is compromised and fluid is leaking and corroding the steel cables so the whole assembly needs to be replaced? There is a similar discoloration near the master cylinder.
(Nevermind the broken trickle charger plug, I have a replacement for that)
