2000 BMW E39 520i, Touring
After snapping the mounting bolt of a rear wheel speed sensor, then attempting to drill the bolt, and use a screw extractor, only for the bolt extractor to snap inside the bolt (really stuck!) I am considering an alternative idea.
If I drilled a new mounting hole for the wheel speed sensor and tapped it, then installed a new sensor, but at a roughly 25 degree angle from standard, would it still work correctly, or does the sensor need to be in a specific orientation?
Thank you.
