I have a 04 Chevy venture. One day as I was rolling up my driver and passenger window from my driver side switch the driver window went all the way up but passenger stopped like 3 inches from closed. I tried to roll driver down from same switch and nothing but I was able to roll up passenger window from passenger switch. I have tried replacing the 30a fuse and that didn’t help. I realized if I had the driver switch disconnected then the passenger switch wouldn’t work. So I kept the driver switch plugged in and pass switch has worked for a few days and now it’s stopped working. The lock button on my driver side even stopped working for a little bit. Today I got new switches for both sides and still not working but now the lock switch on dr side door works again. How do I fix this issue
I don’t know if this info helps at all but my driver side mirror recently got damaged and the bottom of the mirror black housing is cracked off and the mirror isn’t in place.
I just got a used mirror and the switches today at my local junkyard. I haven’t been able to switch the mirrors out but I grabbed as many of the same 30a fuses I could out of some cars just to see if it’s the fuse and both switches won’t work after replacement of both the units and the fuse. The power lock switch did start working again
