I recently changed spark plugs on a 2010 Mazda 3 2L NA engine. I went to a major automotive parts website and ordered the relevant plugs that "fit" this model and year - I chose NGK Iridium IX plugs because I have heard good things about their product. The first plug I installed, I measured the gap against a gap gauge and found it was too tight (ca. 0.04"), so I opened it 0.01". Then I noticed the box says don't bend the plugs.
I figured I'd start the car with other 3 original plugs in place to see if I got a misfire warning, but the car started - albeit slightly rough - and no warning showed up. I went ahead and replaced the other 3 plugs without bending them. The car turns over beautifully now, except the exhaust smells extremely rich. Still no misfire warnings. But my eyes water when I walk around the car and I catch a whiff of the exhaust.
Otherwise, I used a dab of dialectric grease along the ceramic portion of the plug, and I used no antisieze on the threads. I am a complete beginner to automotive repair. I'm having trouble deciding if I did anything wrong and if anything needs to be amended.
Which scenario is possibly the case?
- The old plugs were at the limit of spec and running crazy lean, I am overthinking my reaction to the new plugs. They run slightly rich because the default gap is intentionally at the smallest spec to extend plug life. If anything, the plug I bent should be rebent or just replaced for even wear.
- The website fitment tool is not reliable, and aftermarket plugs are never a real "fit", so and I should have paid triple for the OEM plugs.
- The "no bend" warning on the box is a silly "CYA" from NGK and they should all be bent to the target 0.05" gap for best engine performance/fuel efficiency.
- Something else was wrong with the install.
