I have a Pontiac G6, and the factory CD player stopped working. My sister bought a JVC system with a kit and adapter. When she installed it, the audio was quiet. Everything seemed to be wired correctly. What could be wrong?
  • I take it, the new system powers up, but no sound comes out? Is there a factory amp which is not getting powered on when the stereo is powered? Commented May 4, 2014 at 17:29
  • How can I determine if the amp is/isn't getting power?
    – Alex Volpe
    Commented May 4, 2014 at 19:54
  • I guess you'd have to find the amp (if it exists) first. Then check the wires to ensure it's getting power. There is probably a separate wire in the harness which is not being attached to anything. Your new stereo should have a separate wire (which is not getting used at this time) which is there to energize amps if present. It's going to take some troubleshooting to figure it out. Commented May 5, 2014 at 10:29
-1
I was wrong about the wiring. The speakers were wired to subwoofer outputs instead of the mains.
