not until i restart the car and engage it again .. i already drain the oil and put new oil it still disengages on motion .. what can I do next
  • Welcome to Motor Vehicle Maintenance & Repair! Have you checked to see if there are any OBDII codes present? Are you sure the fluid is filled up to where it's supposed to be? Apr 15 at 15:38
  • Lose/worn transmission linkages allowing the shift to neutral? You'll need someone capable of examining the PRNDL shift mechanism.
    – F Dryer
    Apr 19 at 16:14
