I own a bajaj ct100b motorcycle,it should give me an average of about 70+ kmpl but I'm only able to eke out 40-45kmpl ,i tried taking it to service,tuning the carbs,there was a fuel tank leak and got that sorted out,the spark plug looks fine,does anyone have any idea? A suggestion? Pls lmk thank you
1 Answer
If you drive the bike regularly at 55 kmph, 45 kmpl is normal for that bike (see here). Try oiling the chain and inflating the tires to the proper pressure.
Change the crankcase oil. Add Engine Restore to the fresh oil, one oz. per liter of oil.
Add BG 44k to the gas tank. Drive bike vigorously.
Change the air filter if you have not done so already.
