Are these tire sizes interchangeable for the same set of r8ms?
No.
235/35 has a diameter of 23.8" and a width of 9.6".
215/45 has a diameter of 24.6" and a width of 8.5".
You might be able to get away with 215/40R17 but just buy the proper size for your car. If you're going for a different look, buy different wheels that fit the tire profile you're after.
source - https://tiresize.com/calculator/
-1
Yes, they should work fine, especially on something like a pickup truck.
While the overall wheel diameter will change, it's a fairly insignificant.
The handling may be a bit different however.
