I have a 2011 Chevy Traverse with a P2099 CEL that I can't get to go away. I used an OBD scanner to watch the live O2 and fuel trim data. The downstream O2 sensor on bank 2 (side that P2099 refers to) will register around 0.1 volts for a while, jump up to 0.6 volts for a while, and go back and forth. (NOT rapid fluctuation like the upstream O2 sensors register).
The long term fuel trim on this bank was -7% on this test drive. The saved info with the code showed the LTFT at -9.4%.
From my understanding a low voltage of 0.1v means it is lean. I also understand that a negative fuel trim value means the engine is trying to lean the fuel mixture. I also read that the computer looks at the downstream O2 sensor data to determine LTFT.
So I am confused. If my O2 sensor is registering lean, why is the computer trying to further lean the fuel mixture? Perhaps my underlying assumptions are incorrect, if so clarification would be appreciated.
12
    Have you checked your exhaust for leaks? A leak will introduce air into the exhaust system making the downstream O2 sensor appear more lean than it should be. Feb 28 at 8:11
  • Are you seeing similar fluctuations on the post cat sensor as well?
    – GdD
    Feb 28 at 10:06
  • @Pᴀᴜʟsᴛᴇʀ2 Yes my mechanic already looked for leaks, he said they found a tiny one on the joint right after the CAT and before the downstream O2 sensor. He fixed it. Still getting code and weird readings.
    – Mr. Spock
    Feb 28 at 14:48
  • @GdD The slowly fluctuating sensor I referred to is the post cat sensor bank 2. The post cat sensor on bank one (no code on that side) stays consistently around 0.6v which is what I would expect.
    – Mr. Spock
    Feb 28 at 14:49
    Is Bank 1 Sensor 1 switching back and forth, ie 200-800 millivolts? Feb 28 at 17:30
