Hyundai Accent battery will not charge. Had battery tested, bad, replaced. Had alternator tested, bad, replaced.
I installed the alternator myself, from what I remember it was connected by two plugs, and a belt and those were assembled as I remembered taking them off. Is there supposed to be 3 plugs, a ground or something?
Front headlights also wont work and I've checked all my < 30 watt fuses, all good. I'm about to replace my battery connectors but I don't think is the problem. Belt is not squeaking and seems to be running fine.
I cannot get my headlights to work or my battery to charge. My question is did I install my alternator right, and why is it not charging? Bonus question : Could one of those bigger fuses being blown be the culprit to both my problems?
