Looks like positive would need to be cut out, it's completely locked shut.
Disconnected the negative. Will there be an issue with electrical work conducted, curious
No problem as long as the negative is disconnected. You just have to disrupt the flow of electricity, which is what you've done by disconnecting the negative lead.
  • succeeded: no shorts, no fires, thank you! Commented Jan 9 at 19:41
