10
I recently found out that when jumping a car, you should not connect the black connector to the recipient vehicle's battery, but rather to a grounded point on the car. The expressed purpose is to avoid a spark near the battery, which may potentially be producing hydrogen gas. Some have argued that you can connect to anywhere on the frame. Others have expressed problems with this (probably due to thin grounding wires) and recommend attaching to the engine block.
As an electrical engineer, I am taught to never rely upon a body ground to transmit current. There's plenty of issues with doing this, including the fact that mechanical connections and grounding wires are rarely designed for the high amperage. But this seems to be a special case.
Do automotive manufacturers plan for this sort of jump start as part of their requirements? For example, this would mean making sure that there is a sufficiently robust connection between the engine body and the ground side of the electrical circuitry to handle that sort of amperage. Arguably this connection would need to be as low of a gauge wire as the wires to the starer motor themselves.
10
  • 8
    Several recent vehicle models (the Honda Odyssey comes to mind at the moment, but there are others) have a protruding screw that is explicitly labeled for connecting the negative cable when jump starting. This screw is in the frame that holds the radiator, so clearly the manufacturer is of the opinion that this ground is sufficient. There's a picture of the Odyssey ground screw in this answer.
    – Moshe Katz
    Nov 12, 2023 at 23:39
    I also never understood this. The negative terminal is grounded, and likely can't result in a freak current through a fuse or sensor or something. And the frame is where they are grounded, so, to me, seems an identical path to clamp on the frame.
    – user58368
    Nov 13, 2023 at 15:40
    @58368 additionally, the ground/negative is rarely if ever fused.
    – Criggie
    Nov 13, 2023 at 20:11
    @58368 "seems an identical path to clamp on the frame" seems to go together with "purpose is to avoid a spark near the battery" in a logical way. Am I missing something?
    – JimmyJames
    Nov 14, 2023 at 21:40
    @58368 All I am saying is that if the goal is to avoid a spark near the battery (as claimed,) then attaching to somewhere away from battery (with an equivalent path) seems like an obvious solution.
    – JimmyJames
    Nov 14, 2023 at 22:01
7 Answers 7
12
The question says
The ground cable goes directly (and only) to the frame in this picture
enter image description here Image from Quora
So all the power requirements take this route, notably the starter motor.
In my experience, it is usually easier and more secure to connect to a frame point than to the battery terminal.
9
Compare the circuits formed by the two alternatives:
  • positive jumper cable - positive recipient battery terminal - starter relay - starter windings - engine block - chassis - battery ground cable - negative battery terminal - negative jumper cable
  • positive jumper cable - positive recipient battery terminal - starter relay - starter windings - engine block - negative jumper cable
The difference highlighted in bold will certainly have some positive nonzero resistance, so skipping it reduces the losses in the high-current path through the cranking starter. In contrast to that, charging the dead recipient battery is not a primary goal while jump-starting, so a slightly higher resistance in that circuit does not matter.
If you examine your car or any other vehicle, try tracing battery ground cables. Most, if not all, battery ground connects to the chassis nearby, Chassis has a ground cable to engine block. From your engineering background and business sense, using the 4 or 6 gauge stranded copper wires would fulfill electrical demand (greatest) from starters, meet electrical designs for power distribution and reduce wire lengths for reasonable cost savings. At least one auto manufacturer recommends boosting a vehicle; connecting the positive cable to battery positive (both batteries), negative boost cable from boost battery to the engine block lifting bracket or other engine bracket mechanically bolted to the engine block for ground connection to the starter.
The question was "Do automotive manufacturers plan for this sort of jump start as part of their requirements?"
And the answer is: yes. Every car I've ever owned has a section about jump starting in the owner's manual. If that isn't an indication they've thought about the possibility, I don't know what is.
I guess I'm tempting fate every time I rescue someone by jumpstarting their car, but I routinely hook to the battery terminal and I've never blown up yet.
Finding an bare piece of metal on the frame under the hood of a stranger's car is hard enough. It's usually at 10:00 at night in the grocery store parking lot using the light from my cell phone, too. Everything is painted, powdercoated, or covered in grease, so the engine block or the negative battery terminal is how I roll.
I look at it this way: The danger is igniting hydrogen gas created from a charging battery. If the last connection I'm making is the negative terminal on the dead battery, the charging hasn't started yet; how much hydrogen could possibly be there waiting to spark? Obviously, the amount is greater if they've been trying to charge the battery some other way before attempting the jump start.
I know, I know, someone will link something in the comments proving it's happened before. And people blow up all the time using their cell phones at the gas pump, too... ;)
  • I'm glad someone mentioned how hard it is now to find an unpainted surface under the hood of a modern car. It used to be very easy to find an ad-hoc remote ground. Not so much any more. Nov 15, 2023 at 17:55
    I left a comment above, regarding how rare this risk should be with modern sealed batteries. But it does seem like someone who needs a jump from a stranger is at higher risk for having a battery that is damaged or abused or very old. In that case the risk may be higher. Nov 15, 2023 at 19:07
On many vehicles, where the battery is not in the engine compartment, specific jump start terminals are provided; so you don't have to dig around under the rear seat or in the boot [trunk].
This is how my Merc E-Class is set up [though mine is slightly different & doesn't have the second battery marked here in the engine compartment, only one in the boot.
Picture from MBWorld - Mercedes-Benz E-Class and E-Class AMG: How to Safely Jump Start Your Battery
An older BMW 7-series I had used a similar system.
You'd have to assume if the manufacturers though this was a good idea, then it ought to be 'safe', as well as considerably more convenient.
    It's the same on my transit
    – Chris H
    Nov 14, 2023 at 19:54
Might be getting mixed up between jump starting and battery charging.
With battery charging, there's obviously a charger connected somewhere. And during charging, the battery will give off explosive gases. So it makes a lot of sense that when the charger terminals are connected, one is nowhere near the battery itself. This obviates the chance of sparks - take off the one on the block, or elsewhere first, them the positive can be removed from the vehicle's positive post, producing no spark to potentially ignite said gas.
With jump starting, the leads are on for a very short time, comparably - once the vehicle has started, there's no point at all leaving the leads connected. So both terminals could happily be connected to the battery - probably with less power loss to the poorly vehicle. So no opportunity for gas build-up.
    When jump starting, especially a using a small-engined vehicle to start a big-engined one, with thinnish jump leads, and especially in the cold, you might well leave the leads connected for a few minutes to get a bit of charge into the battery, then run the glow-plugs of a diesel before cranking. I had a 1.0l petrol car and have a 2.4l diesel van - starting the latter from the former took some care
    – Chris H
    Nov 15, 2023 at 14:33
That is correct, you cannot rely on chassis electrical continuity anymore.
The main reason is the widespread use of aluminum body panels. If aluminum contacts steel, galvanic corrosion results. Therefore, aluminum components are isolated from steel, thus they may have little electrical continuity with the electrical grounding network and engine block.
In modern vehicles, the manufacturer provides a designated negative stud which is intended for jump starting, and should be utilized.
You should also utilize this stud for charging. Do not connect to the negative battery terminal, as there is typically a current sensor on the negative lead. Bypassing this sensor confuses the battery management system, resulting a code and disabled features like auto-start-stop, self-driving, and software updates.
