I had a radar detector hooked up to cigarette lighter outlet when all of a sudden the outlet lost power. I tested with other 12V cig cables to confirm and it indeed has no power.
As the first step in troubleshooting I wanted to replace the fuse but none of the fuses are labeled as CIG or anything similar.
Anyone know which fuse is assigned to the cigarette lighter outlet?
EDIT: Apparently, as pointed out by @HandyHowie, there is another fuse box inside the cabin, on the driver's side where the fuse for cigarette lighter is located. It is a 15A fuse and the label is P/OUTLET NO.1. This fuse box is not visible until you dive in head first under the steering wheel and look up.
The fuse you want will be in the passenger compartment.
The user manual for the vehicle shows the fuse box location -
  • Wow, that's highly inaccessible. You have to literally dive in head first under the steering wheel to even see it.
    – Dean Kuga
    Oct 25, 2023 at 18:05
