In attempting to remove my oil-filter, my chain-wrench has broken i.e. the chain part of it. The engine had not been warmed up before(as there is now no oil in the sump) but it was a very hot day.
The filter is so tight it just won't budge.
So I have a broken chain and a squished filter which is still screwed tightly on.
Is there a way to fix the chain, or should I just go and buy another one?
(a related question is how to get the filter off, which I'll post separately)
  • Most canister oil filters recommend screwing them on until it seats, then another 3/4 turn to squish the thick foam gasket. A little oil smeared on the gasket helps with sealing.
    – F Dryer
    Oct 20, 2023 at 3:47
