First time posting! I'll get to it.
First off, i have a 2021 corolla LE.
So the other day I'm driving, and noticed my car wasn't behaving like normal. I looked down at the shifter and it is stuck between the D symbol and B symbol. I can't recall if I popped it back into D while coming to a stop at a light or if I waited until the car was stopped, but I did pop it back into D withing seconds of me noticing it. Also, no funny noises, no jerks, just a lack of response on the throttle I think it was. When I tried to get moving the car felt extremely underpowered and continued this even as I gave it gas. It barely moved. I shifted (smoothly) into park and turned the car off, and turned it back on. Same problem. So I REALLY gave it some gas this time and it moved just enough to pull into a parking space. I put it into park again and let it sit for a while, then started it back up and it felt more normal.
Anyways, that was like 3 days ago. Since then.....
The car feels like it has a 1st, sometimes 2nd, and a 4th gear. It almost seems to skip 3rd. When it slows down, by braking or me just taking my food off the gas, it feels like when you downshift in a manual to slow down the car through the gears but with this it is much MUCH less pronounced. There are no wierd noises, no wierd vibrations (new ones) I drive for uber so I drive all day and have had no problems other than he ones described. Also, last night, i was going like 55 (not for the first time since) and the car sounded like it was REALLY trying to slow itself down through the gears
So, to reiterate:
  • car doesn't shift like normal but drives fine
  • car seems to skip 3rd gear, maybe something else but def a gear in the middle of the set
  • no funny noises or sensations
  • car drives find at speeds up to around 55, 60 is most I've pushed it but still performed okay
  • I can floor it in "D" or "B" and the power is there like normal, up to like 35ish (don't want a ticket).
Please let me know what it is you guys think. Car has 39k miles on it if that helps.
  • Welcome to Motor Vehicle Maintenance & Repair! Oct 15, 2023 at 15:17
  • A 2021 vehicle with 39k miles should still be under warranty? Oct 15, 2023 at 18:03
  • @WeatherVane Most non-luxury cars in the US have a bumper-to-bumper warranty that expires after 36k miles, including Toyota.
    – user71659
    Oct 17, 2023 at 2:45
  • @user71659 in UK 3 years or 60k miles is common, but not less than the statutory one year. Oct 17, 2023 at 9:27
