I have done front brake job - Disk (DIY) on my car. I have used anti-seize for brake contact points, back-side (metallic side) of brake pads, and for caliper guide pins - cleaned existing lube, then sprayed silicone spray around pin, after that I have applied thin layer of anti-seize around the pin and inserted back.
This is my first brake job (DIY). Just worried whether using anti-seize instead of grease on above locations would be a problem?
