2001 toyota 4runner V6 3.4l 2wd SR5
ABS, brake & check eng warning lights are still on after replacing the ABS unit. What do I check next?
    Have you reset the codes?
    – GdD
    Oct 2 at 17:24
    Welcome to Motor Vehicle Maintenance & Repair! And after you clear the codes (as GdD suggests), if any re-appear, what are the exact codes? Oct 2 at 17:26
  • What has the 'check engine' warning light to do with ABS? Oct 2 at 20:33
  • On my Ford several warning lights came up: engine, brakes, ABS, oil. The fault was with the instrument cluster itself. Oct 2 at 21:14
  • @WeatherVane - Many people generically call any dash light as a CEL. Oct 3 at 0:08
