My car is Honda Jazz 2057 Reg.
The high beam for both side are working fine. Only the normal beam on both side are not working. The normal beam and the high beam are from the same lamp.
I have checked the lamp on one side is working. So what might be the possible problem that the lamp on both sides are not working? The fuses for right and left side are OK.
Appreciate any guess. Problem with the switch arm or relay, if any?
