How can I access the AC Flow Sensor on a 2011 Lexus RX350? I opened the hood, remove the plastic covers, can't find it.
Do I need to go under the car to get access to it?
Before you replace the sensor, read my note at the end.
The flow sensor is on the A/C compressor itself:
e
More detail here:
e
NOTE: These images are from ClubLexus.com, where there is a long post that describes fixing the sensor without replacing it. It involves sticking a rare earth magnet to the C-clip that retains the sensor. Suggest you check it out before replacing the sensor. The link takes you mid-way into the 12-page article, so you might want to page back to read it from the beginning.
Photo credit and link to article.
