My 4.3L 4x4 base pickup has the abs engage everytime Im braking at 5-6 mph replaced abs module front wheel sensors and speed sensor on tail of transfer case bleed the abs module with diagnostic tool still engaging when taking it up the road the rear speed sensor trails behind the front and when braking it dips to zero when abs engages the others don't went and cleaned the connections on the ecm nothing what do I do next
  • Did it get better for awhile (weeks?) after you replaced the front wheel sensors? Then resumed engaging every time you stop?
    – MTA
    Jun 29 at 1:12
  • Did you change the front hub assemblies with the sensors or just the sensors? Worn bearings can cause ABS issues.
    – mikes
    Jun 29 at 9:26
  • The issue hasn't went away ever and haven't changed the hub assembly because the front sensors read the same on the scanner I would think if the hub was bad they would be wrong Jun 29 at 11:00
  • Have you checked to ensure your tires are all the same size? Jun 29 at 15:12
  • Tires are the same size Jun 29 at 15:45
The following can also cause issues like this -
  • Cracked Reluctor Ring
  • Rusty Reluctor Ring
  • Worn wheel bearing (allows the ABS sensor to move away from the reluctor ring)
  • Rust stopping the ABS sensor seating close to the reluctor ring
On some vehicles it is easy to see the reluctor ring, on others you may have to remove the sensor to view it. Do they look clean and are firmly attached? Can you see any cracks?
Check the wheel bearing for play.
  • Would t that make the front speed sensors read wrong, an no play in the bearing Jun 29 at 11:07
  • Presumably there are ASB sensors on the rear wheels too? Have you checked those? When you talk about the front and rear speed sensors, does it have 2 or is it getting the speed from the ABS sensors?
    – HandyHowie
    Jun 29 at 12:01
  • There is a sensor on the front and rear of the transfer case I replaced the one that reads the speed going to the rear drive shaft on the tail end of the transfer case with no change in symptoms afterwards Jun 29 at 12:11
  • These sensors drop input to the abs module at 4.5 mph. You should double check with the scanner and check each sensor to see if they all match speed at 4.5 and higher. The one that doesn't match is the problem. If it's a sensor in the tranny, find which one feeds the abs module. Then check sensor reluctor connectors and wiring. It's probably going to be found in these areas.
    – Jupiter
    Jun 29 at 15:37
  • Another thing to check is to see if the reluctor ring is fully seated and not spinning in place. Very rarely would this happen, but it is still a posibility. Jun 29 at 16:04
