I'm working with a 2011 Honda CR-V and the acceleration is abysmal. Is there a way to increase the acceleration? I've tried putting it in D3, put it in D2 and D1.
For example, if I press the pedal to the floor, there is a 3/4th to one second pause and then the engine revs and drives faster. I want to reduce or remove that pause.
It feels dangerous having so much latency in the throttle response.
Update:
The reason I ask is that maybe the "line" to the accelerator is too long like a hand break on a bike that has too much slack. If this could be tightened up so that there is no slack.
Or maybe there is a drive mode that it is stuck in. I've seen drive modes on numerous vehicles.
I've driven vehicles in the past that are quick to respond, and usually they have been more expensive.
