I got a new digital clock for my car (1988 Accord) as the old one was broken. It came without that front cover/bezel/plastic chassis so I intended to swap it into the old bezel/plastic chassis from the broken clock.
Before doing this I was able to plug it in and test it - it worked fine.
So, I simply soldered the wiring from the new clock onto the socket-pins embedded into the old clock's bezel/chassis (the socket is part of the plastic casing).
And it no longer works. I tested power to the circuit board and that's all good, but the clock its self is just not working.
Could it be possible that when soldering on the wires to the socket-pins I some how heated up the circuit board? I'm puzzled as to how this could've happened. Old, Broken clock
New, Working clock
    Can you add some photos?
    – HandyHowie
    May 28, 2023 at 7:32
    Did you connect the wires with the correct polarity?
    – HandyHowie
  • @HandyHowie I believe I did (I took photos). The only difference was a one of the four wires was a different colour (green VS yellow). Will upload photos I have shortly.
    – MeltingDog
    May 28, 2023 at 23:47
  • Tried to upload photos but it seems Imgur is down?
    – MeltingDog
    May 28, 2023 at 23:55
  • 3
    The black wire is in the same place on both photos, but the coloured wires are in totally different places. Is that correct? How did you know where to connect the different coloured wires?
    – HandyHowie
    May 29, 2023 at 8:03
