The title question says it all. My Goggle-Fu isn't strong enough to find any conversion charts. The only size-related markings on the current tires are 65-405 (2.50-16). I believe they are motorcycle or motorcycle-sidecar tires with a tube.
From what I'm seeing, the 2.50-16 is the current size. Doesn't look like there's a large selection out there but you can find them. They are shown as a front tire. A Google search for "motorcycle tire 2.50-16" gave me a pretty good list of things.
EDIT: To clarify, the 2.50-16 is 2.5" x 16". This is imperial sizing for the tire. Also, if your rim requires a tube for the tire, you can get a tubeless tire and still put a tube in it to keep the air in. Either kind of tire will work.
    OK, I finally found them in local shops too. I think it was the rarity that threw me off, because I tried searching for that "2.50-16" and came up empty handed. Thanks!
    – Vilx-
    May 8, 2023 at 22:51
  • A local shop just replied to me that they don't have the 16x2.5 that I ordered 3 weeks ago, but that they do have 16x1,75-2,1. It's close... do you think it would still work?
    – Vilx-
    May 29, 2023 at 13:56
  • @Vilx- That'd be 30% skinnier tires. I mean, they'll fit, but that's a LOT smaller than stock. I wouldn't run them, but that's up to you. May 29, 2023 at 14:12
  • OK, I'll keep looking. Thanks!
    – Vilx-
    May 29, 2023 at 14:14
