The problem is that all the sellers of the cabin filters provide filters for the BZ0 (I was told that my BZAF05 is BZ0) variant with dimensions of about 260 x 170 mm, while when I tried to measure the space for the filter, I guess that it's about 230 x 150 (it's difficult to get in) and the old filter I got outside was seemingly bent.
If I set it on this website, there are no exact dimensions, just similar. Unfortunately, it's not in the user manual either. I am not having the repair manual.
  • Have you tried just seeing what the number is listed on your current CAF? May 2, 2023 at 19:46
  • @Pᴀᴜʟsᴛᴇʀ2 What is CAF?
    – Juandev
    May 2, 2023 at 21:34
  • Cabin Air Filter May 2, 2023 at 21:43
  • Its Filtron K 1300 A. The websites show dimenssions 260 x 149 x 34 mm.
    – Juandev
    May 2, 2023 at 21:46
  • I"m saying, the part number should be written on the original filter. Did you look at it at all? May 2, 2023 at 21:55
Normally I consult an online catalogue of the more reputable brands to verify the correctness.
The Mann catalogue says that the CUK 26 005 with 260 x 150 x 35 is the right one (apparently for the entire Megane 3 series).
