I've had to put a new ignition switch and barrel in due to the other one faulting I've put it all back together but now when I turn the key there's nothing no dash lights and not starting I'm in need of some advice please
  • Welcome to Motor Vehicle Maintenance & Repair! Apr 5, 2023 at 23:18
Did you disconnect the battery before you replaced the switch? If not, did you notice any sparks? You may have blown a fuse or the fusible link if your car has one. The fusible link would be found in one of the not-so-thick wires attached to the + terminal of the battery.
