My boyfriend drove me to dr. Yesterday at 70mph with my Honda Pilot in 2 nd gear. Did he damage my car?
  • Welcome to Motor Vehicle Maintenance & Repair! Apr 5, 2023 at 21:37
  • Was it just for a brief period, at that speed in second gear? Had he selected 2nd by mistake?
    – HandyHowie
    Apr 6, 2023 at 5:49
Probably not since most modern cars have rev limiters in the ECU. This prevents over-revving the engine and causing damage.
You may want to consider upgrading your boyfriend, though.
If there were any real damage, you would know right away. Listen carefully for any unusual whirring sounds, hard shifting, etc. during normal usage.
You might consider having the transmission fluid changed at a shop. Running the transmission at a sustained, high rate could easily overheat and sheer the fluid. Worn fluid will cause damage to internal metal parts before long. A servicing costs about $125 for your vehicle and would be well worth the effort.
