I have a Lincoln Continental 2000 and had changed the fuel pump one time and it worked for about a month and after a month the fuel pump failed again and confirmed it failed by applying 12v and ground to the fuel pump motor with a car battery. After that I bought another fuel pump and changed it and I noticed that the connector has 12v and ground but as soon as I connect it to the new fuel pump, it loses 12v, I checked with the multimeter on the fuel pump motor. I checked with other fuel pump motors that I have, not knowing if they work or not and it does the same thing, 12v disappear. When fuel pump connector is disconnected, there is 12v. I have changed the FPDM and the ECM as well to see if it would make a difference and it did not. I think this could be a wiring or a fuse box issue, since I already changed ECM and FPDM. Although I am not sure, does anybody why this is happening?
  • When you say "12v disappear" ... what do you mean? How exactly are you testing this to see the 12v drop completely? Mar 29 at 18:59
  • I am probing the positive and negative side with multimeter on the fuel pump motor. Mar 29 at 20:57
  • Are you just testing at the plug with the pump plugged in? If so, you should try between the hot side and directly to ground (not the ground wire). Mar 29 at 21:18
You must have a bad connection somewhere in the wiring with a high resistance, rather than a completely broken circuit that you would get from a blown fuse.
With no load connected (the fuel pump), the high resistance would allow you to see 12v at the fuel pump connector. Since a very small current is being drawn by the voltmeter, there will be no significant voltage drop (ohms law).
Once you connect the fuel pump, the fuel pump's low resistance will attempt to draw a larger current. This will then cause a large voltage drop across the high resistance bad connection.
I would start by probing the fuse for the fuel pump to see what voltage is present there while the fuel pump is powered up. If you see 12 volts there, then you know that the bad connection is after the fuse. If it is a low voltage at the fuse, the issue is before the fuse.
  • I connected my autel scanner and used the fuel pump on/off feature to activate the fuel pump and it successfully activated the fuel pump motor. I dont know why it does not activate by itself when key is on half way. Apr 15 at 3:54
