Got a Toyota Corolla E170 and it is only used for highway travels twice a month. Car has a tracker installed as well.
I want to give the battery (lead acid 46AH) a top up using battery charger (10A) after every week so that battery remains charged since ECU and Tracker use battery to keep information saved and tracking the vehicle. The charger has Three-phase charging modes, Constant current, Constant Voltage and float charge. Although battery isn't discharged, just want it to start the car every time I want it to.
I searched many questions but couldn't get an answer about the car components including ECU and Tracker. I don't want to lose ECU information or getting automatic calls from tracker company by disconnecting battery. Will charging without disconnecting battery damage ECU or tracker or any other component?
