I have a 2006 Citroen C4 1.6 VTR+ (5 doors).
I need to change the brake discs and pads so I ordered those parts from this website. I took them to a garage to get them fit, but they told me the parts are not correct; they are too big. I contacted the website and they will exchange them.
But first, I need to know how to know exactly the parts for my car.
The details of the (incorrect) brake discs:
Front:
  • Thickness [mm]: 26,0
  • Type: Internally Vented
  • Centering Diameter [mm]: 66
  • Diameter [mm]: 283
  • Height [mm]: 34
  • Hole Arrangement / Number: 04 / 06
  • Minimum Thickness [mm]: 24
  • Pitch Circle Ø [mm]: 108
Rear:
  • Thickness [mm]: 9,0
  • Type: Full
  • Centering Diameter [mm]: 71
  • Diameter [mm]: 246,5
  • Height [mm]: 35
  • Minimum Thickness [mm]: 8
What are the correct brake pads and discs?
7
  • Can you give us some more information about your car? I see there are different models for the C4, namely is it a three door, or five door? Is it the coupe, Picasso, or Grand Picasso? What exactly did the mechanic say was "too big"? Was the diameter too big or was it too thick? Which ones exactly did you buy? Mar 27, 2014 at 10:50
  • @Paulster2 is the 5-door hatchback. The diameter was too big. I checked and approx. it's 10 inches the front disc, and 9 inches the rear one (I measured it with the wheel on).
    – SERPRO
    Mar 27, 2014 at 10:58
  • I'm seeing two different sizes, 266mm and 283mm. Do you know which one you bought? Do you have the part number? Since the discs are too big, the pads are probably the wrong ones as well. Don't know for sure, but you should probably have that checked as well. Mar 27, 2014 at 11:56
  • Sorry, those sizes are for the front end. Mar 27, 2014 at 12:08
    Well, the rear disks are the smaller ones. The front ones are the larger ones. I'd have the rear ones double checked before you return them, but it would appear the front ones will have to be replaced. To be sure, you could also just ask the mechanic which ones you should have purchased. Mar 27, 2014 at 12:26
Specify your engine please. Do you have petrol or diesel engine? How many kw/Hp is your engine?
It would be helpful to know the exact month and year your car was made. C4 model parts were updated in October, 2006. That may be your issue. You may have searched for parts from 10/06+, but your car spec is from before that date.
Discs for 2006 Citroen C4s made before October 2006 should be following:
FRONT OEM numbers:
  • 4246W1
  • 424916
  • 424983
  • 4246W7
  • 424915 (Dimensions: 266x22)
REAR OEM numbers:
  • 424919
  • 424932 (Dimensions: 249x9).
You should be able to find them at your parts dealer with these numbers.
7
  • thanks for your answer. The engine is 1.6 petrol and it was registered in January 2006 I think it's 110bhp
    – SERPRO
    Apr 4, 2014 at 10:48
  • ok, I´ll try to get the answer to you asap
    – Mustafa105
    Apr 4, 2014 at 10:50
  • this should be your engine: 1.6 16V 80Kw NFU (TU5JP4), can you confirm?
    – Mustafa105
    Apr 4, 2014 at 11:06
  • I think you are right. but I don't have the papers with me right now. Looking in the Wikipedia it seems the only possible.
    – SERPRO
    Apr 4, 2014 at 11:22
    I am psychic :D just kidding, I am using my parts dealer website autodily-sklad.cz, but it´s in czech so you won´t understand that possibly, but I believe there a many resources where you can find this kind of info, for example, just be simple search I have found this for you bestpartstore.co.uk/citroen-c4/c4-lc/18333/10132
    – Mustafa105
    Apr 4, 2014 at 11:42
