23
I have a 2005 Subaru Legacy 2.5i Wagon.
I just destroyed the passenger-side rear tire.
The tires have approx. 6/32" tread remaining, per an informal measurement with a coin (I used this guideline from tirerack.com)
These are Nokian tires, and according to the specs I found online, they have 11/32" tread depth when new.
Another article on tirerack.com on this topic, suggests that Subuaru states that the differential among tread depth should vary no more than 2/32"
My owner's manual does not specify the what difference in tread depth tolerance is, however they do point out that I have a dashboard indicator "AWD" that will flash if the vehicle is driven with tires of different diameters, and I assume, the drive train is in danger of being damaged.
Among my family and friends, I've received conflicting opinions regarding whether I should replace all 4 tires immediately, or if I could potentially purchase the same brand and model of tire, whose tread depth, I assume, would be 11/32" and be different by approx. 5/32" from the existing tires.
Does anyone have a definitive answer as to which option I should choose?
Is it true that tread-depth can influence tire circumference enough that driving my Subaru for an extended period of time would damage the drive train?
CONCLUSION: I chose to replace all 4 tires with new tires, and I'm happy I did.
7
    I do not have a definitive answer, so will leave this as a comment. While it may seem wasteful, you could always just buy one new tire and have it shaved down close to what the other three tires are. This would be a lot less expensive than having to buy four new tires. I would not suggest running different size tires on your AWD Subie ... but that is my opinion and not a definitive answer. Mar 23, 2014 at 23:46
    I've just read a few posts about this topic, but in the end I believe the best thing for you to do is to phone the Subaru agent and ask them what the difference in tread depth can be. Don't make the mistake of asking if you should change all your tires because that gives them a gap to sell you a new set. What you want from them is information. Mar 24, 2014 at 9:31
    @jmsmcfrlnd ... I think shaving is common enough. A lot of people who do weekend track racing (closed track road course) do it to their brand new tires. On the track it provides better traction, though it definitely reduces overall tire life. Mar 24, 2014 at 9:51
    I had another thought ... you could also see if there are any used tire shops in your area which might have the tire you're looking for ... for a reasonable price, you could be back rolling again. Mar 24, 2014 at 21:26
    @Paulster2 I did end up at a used tire place, but they did not have a sufficient match that suited my comfort level. I also discovered I could have purchased 4 used tires as well, as a means to get by.
    – qxotk
    Apr 8, 2014 at 23:34
3 Answers 3
11
I do: you need matching tires.
That said, it's your car and you have to make the decision. I'd tend to replace all four. @Paulster2 also makes a good point that you could shave down a new one to match.
Let's start by looking at one of the most useful paragraphs from the Tire Rack article that you cite:
Four-wheel drive and all-wheel drive vehicles are equipped with additional differentials and/or viscous couplings that are designed to allow momentary differences in wheel speeds when the vehicle turns a corner or temporarily spins a tire. However, if the differentials or viscous couplings are forced to operate 100% of the time because of mismatched tires, they will experience excessive heat and unwarranted wear until they fail.
What that means is that a mismatched tire won't break your drivetrain immediately. It's more subtle than that: at least one differential will be loaded all of the time and at all operating speeds. So, instead of managing the different rotation speeds in a relatively low speed turn, you'll be cooking your differential at highway straight line speeds.
It's good that there's a light but, frankly, you can hear the differential being overworked if you listen for it. On my Subaru, if I inflate the rear tires to match the front tires' pressure (approximately 4 psi up), I'll hear a distinctive high-pitched whine from the center differential every time I coast down from speed in second gear.
Note: my car is a manual transmission WRX. You may have different audible symptoms in other vehicles and transmissons.
In the end, the reason that the tires should match is the same reason that you shouldn't tow an AWD car (instead they should be flat-bedded). If the back wheels are turning at speed for miles but the front ones are not, the center differential will burn itself up in short order.
Is one mismatched tire that extreme? No, of course not. It will wear your differential, make worrying sounds and affect your handling.
You still have to make the call, though.
    Great last line of your answer; and I did just that: I made the call. I chose to purchase 4 new tires. I don't like worrying of any kind. :)
    – qxotk
    Apr 8, 2014 at 23:33
    @jmsmcfrlnd, I'm glad to hear it. Hopefully this set will live their entire natural life!
    – Bob Cross
    Apr 9, 2014 at 0:32
  • @jmsmcfrlnd If you ever have the same problem again, you can just have a single new tire shaved to the same diameter as the 3 good ones.
    – kdbanman
    Jan 27, 2015 at 16:13
I had the same issue. One tire needed to be replaced, tire store told me I had to replace all 4. Not wanting to give up good money for no reason, fearing they were just trying to get more money out of me, research led me to replace all 4 for better peace of mind and for a longer lasting Subaru. But the tire place did tell me if I purchased the insurance on the tires, if one tire is destroyed they have to replace all 4 for free. So call me a sucker, I purchased the insurance. But I sleep easier.
P.S. I sell insurance for a living, so maybe that made it an easier sell for them.
  • Would you be open to posting the approx. cost of the insurance (perhaps as a % of total tire cost)?
    – qxotk
    May 18, 2015 at 21:26
-3
The way I see it is that if that is the case then subaru wouldn't put a spare tire in your trunk if you can't use it. as long as it is the same size from all four then you should be fine. Now if you used a different size tire on it then obviously it would be good for the vehicle. oh ps for the insurance guy ^^ I work at a tire shop.
  • 4
    Hi, unfortunately I believe this answer needs to be down-voted as it is simply uninformed. Yes, Subaru puts a spare in the rear cargo space of my Legacy wagon, and it is a temporary spare-use-only tire (doughnut). Clearly it is not useable as a replacement to the damaged tire.
    – qxotk
    Nov 11, 2015 at 12:05
  • maybe so but if it were to put "undue wear on the drive train" then they would have included a full-size spare. His answer is legitimate. I agree with him and i operated a service center for ten years.
    – John Lord
    Jan 15, 2019 at 20:37
