I initially was putting a new carb on but decided to just keep the stock one. I have put it all back on. But when I started it it instantly when full throttle. So I did some research and learned about the static governor. I adjusted that and now the bike starts then dies like i turned off the power. What do I do?? I feel I I’ve done everything and I almsot just wanna give up😂
I guess I'd expect it to stop when you turn off the power. Perhaps you meant to ask something else.– jwh20Feb 22 at 23:13
1@jwh20 The OP didn’t say that it dies when he turns off the power, he said that it dies like when turning off the power (re-worded).– HandyHowieFeb 22 at 23:49
Did you remove the original carb, then replace it? What exactly did you do?– HandyHowieFeb 24 at 11:21
