I have an old truck Dodge Dakota I don’t drive very often. One of the tires,the front passenger side tire, needs to be replaced. All tires are 205/75r15. Is it OK to replace the one tire,front passenger tire, with a 215/75r15 size. The other 3 would still be 205/75r15
In an emergency it would be OK but you should not do this over the long-term.
The problem is that the different sizes may affect steering, handling, and especially braking performance. If you have ABS that could be adversely affected too.
  • Thank you. I think I’ll just keep it as a spare. I appreciate your answer. Thank you.
    – GypSea
    Commented Feb 22, 2023 at 22:48
  • If put onto the drive axle, it can also cause issues with the differential. If a 4x4, could negatively affect the transfer case. Commented Feb 23, 2023 at 16:53
