Nearly every plane uses Oleo Struts, they basically look like a shock absorber that is made beefier to also be able to provide springing to the suspension. Normal car shock absorbers also have nitrogen gas but they have very small amount of nitrogen, they can not provide much springing effect however these oleo struts have much more nitrogen and basically work like a spring+damper unit. The nitrogen gas is compressed and acts as a spring. Hydragas is very close to this system that was used in british leyland cars however apart from those cars, this type of suspension is never used. Wouldnt it be simpler to make an oleo strut instead of seperate springs and seperate dampers, oleo struts also take much less space. Why did cars always stuck with coil or leaf or torsion springs? Oleo struts save a lot of space and they dont necessarily seem to be expensive i think. Its basically a beefier shock absorber and lets you get rid of an extra coil spring etc. Also for example oleo strut and hydragas cutaway below. Hydragas even took it a step further and intercoonected front and rear suspension together via the fluid to eliminate pitch and it was also used in a lot of budget cars meaning even that system with extra fluid lines to connect suspensions together wasnt that expensive.
I find your question confusing. You are asking "Why are x and y not used in automobiles?" but you give examples where these systems, or ones similar to them, ARE used in autos. Please clarify your question.– jwh20Feb 19 at 12:28
1Hydragas Service says "Hydragas displacer units gradually lose their gas over time, which is perfectly normal. When new the charge of gas was expected to last a maximum of 15 years which was the estimated life span of the car. No provision was provided by the manufacturers to replace the gas and many of the units are now over 30 years old. Most are so low on gas that the ride quality they give is now severely compromised and low gas also heightens the chance of unit failure."– Weather VaneFeb 19 at 18:10
1If I'm not mistaken, nitrogen gas improves decades old shock absorbers by reducing the tendency of shock oil to foam up, reducing a shock absorbers ability to dampen road shock. Nitrogen filled shocks have a finite life no different from non gas filled shocks. Btw, vehicle shock absorbers are oleo struts since oil is the main fluid whether in aircraft or cars/trucks/suvs.– F DryerFeb 19 at 20:05
1 Answer
Aircraft parts are designed to perform a function at the lowest possible weight that is consistent with safe and reliable operation. If a single part such as an oleo strut -- essentially a shock absorber with spring force derived from gas pressure -- can do the job of a shock + coil spring but without the weight of the coil spring, that's a big plus.
Oleo struts . . . dont necessarily seem to be expensive i think.
Not true. A quick search online reveals that the least expensive oleo struts for small general aviation aircraft are in the $1000 range (each!), and some for twin engine planes cost in the $5,000 - $10,000 range and up.
Yes, everything for aviation is more expensive, but let's be real. Oleo struts are simply too expensive for general use on cars when separate shocks and springs work fine.
