I want to put winter tires on my Echo. Some are available from a Hyundai but they have a different diameter. Will it be safe to use them?
1 Answer
Your Echo takes 175/65R14 tires and the 175/65R15 tires you are considering are:
- Not going to fit on your existing rims. So you would need to buy new rims as well as new tires.
- Unlikely to provide the needed clearance and will likely rub the wheel wells.
So no, you should not use this size tire with your Echo.
