I have a CVT in my patriot and want to install a temp gauge without a T-Fitting since it will be more accurate coming from the transmission itself. I can not seem to find the test port on the transmission anywhere... does anyone know where it is located?
  • Have you checked to see if the Live Data coming out of the ECM doesn't already have that information for you? Nov 5, 2022 at 22:36
  • no, 1) I have no idea how to do that and 2) if it does, wouldn't it be displayed on the cluster or such?
    – Noah
    Nov 5, 2022 at 23:27
  • You need a scanner to be able to do this, but they are relatively cheap. A lot cheaper than putting a temperature gauge in manually. You can get the information through your OBDII port (AKA data link connector - DLC) Nov 6, 2022 at 0:03
  • it wasnt too expensive putting a voltmeter in, i think i might just have to use a t fitting, and put it right before my transmission cooler, that would give the most accurate reading i believe
    – Noah
    Nov 8, 2022 at 21:44
