I have Suzuki alto 2016 with manual gearbox. (Small car with 1.0 liter engine with 3 cylinders)
Sometimes, not always when I start moving in first gear at the moment when the engine speed equals the wheels speed (the moment when I need to release the clutch) I feel and hear a very strong shock in the whole car.
The strange thing that months can pass and it may not occur again. It mostly happens if I drive in a hilly area, but it doesn't end until I give the car a rest with a shutdown engine.
What do you think it could be?
I think if these were the motor mounts I would experience the problem regularly.
  • Welcome to Motor Vehicle Maintenance & Repair! Oct 27, 2022 at 10:00
Motor mounts are a possibility but I would expect the problem to show up at other times as well. Basically anytime the engine is putting pressure on the mount and it's able to move.
Some other possibilities:
  1. Broken gear in the transmission.
  2. Bent or worn shift fork
  3. Failing CV shaft joint
  4. Broken suspension component
  5. Worn or damaged clutch
  • I would double check the motor mounts - I once drove a Mazda Miata which would shake very hard when launching the car, but as long as the long as the launch was gentle, you would not notice. Mar 26 at 23:28
