I accidentally washed my key fob in the washer. My toyota has a push start button. We have use a hair dryer on it. Still won't work
  • Welcome to Motor Vehicle Maintenance & Repair! Try taking it apart and drying it, then put a new battery in it. Oct 23, 2022 at 22:31
  • does it work if you hold it to the button? Likely its beyond repair unfortunately but holding it to the button may still work.
    – narkeleptk
    Oct 23, 2022 at 23:22
  • The best way to dry electronics is using dessicant or in a pinch, dried rice, however that takes days to work and it's unlikely to resurrect your fob.
    – GdD
    Oct 24, 2022 at 8:30
  • My husband called someone. We are going to get it towed there and they are going to give us a new key. Thank you for the feed back Oct 25, 2022 at 1:10
