My R56 Mini had trouble starting (5-7) cranks to start it and lots of misfires, bad idling etc. I originally posted the problem here and tested for fuel pressure, it is nominal thought.
After replacing ignition coils, misfires are gone and the car runs smooth once started! Hurray! But the starting problem still persists! Could it be due to bad VANOS solenoid eventhough I dont have rough idling its really smooth idling after the replacement of ignition coils.
These are the new fault codes I am getting:
P1105 - Differential Pressure Sensor Intake Manifold Pressure Too High (Bank 1)
P111A - Mass or Volume Air Flow va O2 Sensor Too High (Bank 1)
Does this combination of code hint towards something?
