Got the car serviced last Thursday. Since then, when I drive around I hear a loud tweeting noise from the front driver side, if I turn the wheel left and right it goes louder and quieter, if I apply the brake it stops any ideas ?
    What did they do in the service? Did they work on the brakes?
    – GdD
    Aug 9, 2022 at 8:32
From your description, it seems the brake "squealer" has started to rub against the brake rotor. This is a tab which is attached to one of the two disk brake pads. When the friction material gets worn to a point, it makes contact with the rotor and starts making noise. The tell tale is, when you engage the brakes, the noise goes away.
Have your brakes checked.
  • These are new pads though. Only been on one month
    – venomx
    Aug 19, 2022 at 7:40
I've had similar symptoms when a small piece of gravel was stuck between the backing plate and the caliper. Another reason could be a slightly bent backing plate.
