Thanks in advance. My 2014 Tucson ac fan will. Not shift in high mode. I replaced the fan which had a new resistor. I have switched the 30 amp relay still no help. Any help? Thanks
    Are you saying that the fan will go at low and medium but turns off when you switch it to high?
    – GdD
    Aug 5, 2022 at 13:04
  • Welcome to Motor Vehicle Maintenance & Repair! Aug 5, 2022 at 13:04
  • Does this model have a switch or is it an electronically-controlled fan?
    – jwh20
    Aug 5, 2022 at 16:18
  • It is the ac condenser fan. It only comes on when engine is warmed up. It will not go to high when I turn on the ac. Thanks Aug 27, 2022 at 0:56
