My 2000 Dodge Durango SUV has a 4-pin trailer light connector next to the towing hitch. Nearby, tucked up near the exposed spare tire, is this cable:
Looks like two contacts, although there may be a third contact recessed in the center.
Does anyone recognize it?
  • It may have been there for options not on your vehicle, so is likely not important. Does the vehicle have reverse sensors?
    – HandyHowie
    Jul 18, 2022 at 7:07
  • I thought it might be a connection for an electric trailer brake, but have been unable to locate matching images.
    – fred_dot_u
    Jul 18, 2022 at 8:42
  • No reverse sensors. I, too, was hoping it would be trailer brakes, but it turns out I don't have the factory-installed optional Towing Package. I'm going to have to add an after-market trailer brake controller. If I'm lucky, this might be a wiring harness to be used by a brake controller, and so would make my installation easier...
    – bitsmack
    Jul 18, 2022 at 11:10
  • Did you check to see if it goes to the license plate light? This is a low amperage connection judging by the size/shape, so couldn't be for much more than a light bulb. Jul 18, 2022 at 13:32
