My car starts sometimes then others it doesn’t. I have a 2006 Lexus is350. All electronics work when I push to start, Battery connections are fine, just replaced the alternator, tried my best to check all wiring is good and replaced a blown fuse but yet it’s on and off.
Not sure if it’s the starter/solenoid because it doesn’t make a clicking noise just sort of a hissing noise under the car by the downpipe drivers side when I step on the brake and push start, also where the starter is located
  • Welcome to Motor Vehicle Maintenance & Repair! Jul 10, 2022 at 14:48
  • hissing like spinning?
    – rogerdpack
    Jul 12, 2022 at 6:52
