Im the proud owner of an ER-6F from 2009.
I just tested my bike for leaking current and noticed it did. When pulling the fuses I found the ECU to be the culprit. I assume this is not normal. What do i need to do?
Welcome. Start by telling us exactly which bike it is. Also do you have the wiring diagram for the bike?– HandyHowieJun 21, 2022 at 9:51
It's an ER-6F from 2009. I have the wiring diagrams In my haynes book. Just added it to the post– Andreas DamenJun 21, 2022 at 9:56
Thanks for adding the wiring diagram. Which numbered fuse did you pull?– HandyHowieJun 21, 2022 at 10:00
On the fuse box it says "15A ECU". Which i believe is "F3 Engine Management" on the diagram.– Andreas DamenJun 21, 2022 at 10:04
The wiring diagram indicated that fuse 3 supplies the instrument cluster, the ECU and the ECU main relay. I would start by unplugging those individually to find out which one is drawing the current.– HandyHowieJun 21, 2022 at 10:18
