7
I got an oil change awhile back, I notice my car idling a little more. Where I park for work it was hard to tell what the oil leak was coming from on the ground. I don't know much, but I popped my hood and the dip stick was not fastened, and oil was spewing everywhere. Now my spark plugs that are under my coil packs are covered in oil (from the bottom actually) and when my car idles down it shakes more. I tried to clean everything the best I could. I know I should get nee spark plugs and so on. Main concern is how so much oil got to the bottom of the spark plug where it screws in? Could I have damaged my engine? There is no knock. Could it be flooded?
5 Answers 5
If the oil looks like it could have come out of the open dipstick tube, which is entirely possible, then I would suggest that you get the engine thoroughly cleaned using a jet wash and engine de-greaser so that you can see if any more oil appears from anywhere else. (Don't hold the jet wash lance too close to the engine in case you force water passed any rubber seals though)
There is no point performing any work on the engine until you identify exactly where the oil came from.
Also check the oil level regularly to make sure you don't cause any damage to the engine.
Oil being pushed out of an open dipstick tube could be normal for the engine if the dipstick was not fastened in correctly, but it could also be an indication of the crank case ventilation system being blocked or even a sign of a worn engine allowing too much combustion gas to pass the piston rings.
Check the oil level, get the engine cleaned and keep an eye on it, then report back with any sign of more oil escaping.
  • 3
    Be careful with suggesting "I would suggest that you get the engine thoroughly cleaned using a jet wash and engine de-greaser" so carelessly. Far too many people end up causing electrical issues for themselves because they got water into places it should not have gone. youtube.com/watch?v=PRSoRkM8GcM is an excellent video.
    – MonkeyZeus
    Jun 6, 2022 at 14:28
  • @MonkeyZeus I don’t think I am being careless, I did say not to put the lance too close to the engine so that water does not get forced passed any seals. I have used a jet wash on many dirty engines and have never had an issue. The worst I have seen is the need to dry a distributor cap or the HT leads. However, I am happy for you to add your concerns.
    – HandyHowie
    Jun 6, 2022 at 16:25
    Sounds like "jet wash" is causing disagreement. Personally I'd use a gentle sprinkler, with minimal force. The degreaser spray is doing the real work and just needs rinsing off not a powerful pressure.
    – Criggie
    Jun 6, 2022 at 21:32
    @Criggie You may be right. I guess that is what the voting is for. Maybe my idea of using a jet was isn’t what some people imagine. They don’t have to be used at point blank range to work.
    – HandyHowie
    Jun 6, 2022 at 22:11
Oil contamination can cause rough running, if you clean it off properly it should be fine. You don't need to replace your spark plugs, they won't be damaged by oil. The rough running is most likely due to oil contamination causing electrical problems, for instance fouling the contact between your coils and plug terminals. You could also have contamination where the ignition cables connect to the coils, or the coils could be soaked by oil in which case you'd need to replace them.
So start with a thorough cleanup of the engine and get all the oil off where you can, then use a cleaner to clean the contacts. Once that is done see how it runs. If you still have problems check on your ignition cables.
There are other things that could have gotten contaminated by oil, for instance sensor connections. A close examination backed up by a check of your OBD codes is a good idea to catch any other issues.
You don't mention what kind of car this is, but the crankcase ventilation/recirculation system on many modern vehicles is such that the fuel/air mixture will be a little bit off if the crankcase is not more or less sealed from the atmosphere -- for instance if the dipstick tube is not inserted all the way.
This would explain your rough idle -- the oil spraying everywhere out of the dipstick tube is somewhat to be expected, but could also be a sign of excessive crankcase pressure due to either of:
a) blowby due to worn piston rings
or (hopefully)
b) a clogged PCV valve or crankcase gas recirculation system
GM 4-cylinder engines are quite known to experience the latter in the area of 100k miles or sooner (see here); note that although the TSB applies to model years ~2010-2013 the underlying problem still exists in newer engines.
This would be good to attend to, as excessive crankcase pressure may have caused the dipstick to blow out, and if the dipstick doesn't blow out could create an oil leak around the crank seals.
You can test it yourself roughly by pulling the dipstick with the engine running and putting your thumb over the hole to see whether there's pressure or suction -- there may be slight pressure at idle, but if you rev the engine to ~1500 rpm there should be vacuum causing your thumb to stick to the dipstick tube a little bit. I'd suggest getting a mechanic to take a look if you are at all suspicious; it should be cheap, and fixing the problem can be a bit involved so you will probably want it done professionally anyways.
The oil around your sparkplugs is probably not a big deal, although it's not exactly great for your coilpacks etc; "clean it up as best you can" is the best bet here. If you have a shopvac (that you don't mind getting oily) you should be able to suck most of it up with a small nozzle.
If you can add the make/model of your car to the question, it may be possible to provide some more specific answers and possible DIY advice.
-1
How far back? How much driving have you done since then?
Hmm, a simple oil change shouldn't cause this.
Not good.
Who changed your oil? I would go after them for damages.
It definitely makes things dirty but dirt isn't inherently an issue all by itself.
After putting your dipstick back in place did you check your oil level? How low was it? I hope you've topped it off.
This is likely not responsible for the shaking unless it's interfering with the operation of the spark plug. Odds are you would be getting a check engine light and cylinder misfire codes.
You've been low on oil for an indeterminate amount of time, you've possibly damaged your engine. Top it off with oil and see if it stops shaking.
-2
The oil in the spark plug wells is due to the seals failing and needing to be replaced. This is not that unusual. It is unlikely you have done any harm to your engine. If it were to get bad enough you would have experienced a misfire and a check engine light would have come on.
Replace the well seals and since you have to remove the valve cover to replace the well seals you might as well replace your valve cover gasket as well. Often times the valve cover gasket and well seals are sold as a bundle.
  • 3
    It seems untoward to consider failed seals when the OP states that the dipstick wasn't secured and oil was being ejected from it.
    – fred_dot_u
    Jun 6, 2022 at 7:36
  • It is very accurate to consider failed seals. There is enough oil in the wells to cause concern to the OP. There is a great possibility that there's more oil in them that would be caused by oil spraying up from dipsticks tube. Without actually seeing things, it is a very likely possibility.
    – Jupiter
    Jun 6, 2022 at 10:50
  • This is not good advice at all, the poster could spend a lot of time and money replacing seals that are perfectly fine. Leaking seals also does not explain rough running.
    – GdD
    Jun 6, 2022 at 13:29
  • It is extremely unlikely the oil from a loose oil dipstick got to the bottom of the sparkplug well through the coil pack. The fit is too tight for oil to leak from the top down. As the OP stated the oil is "from the bottom actually" would clearly indicate the oil came through the tube seals. Also, read the OP's questions - he is concerned about the oil getting into the spark plug well and any potential damage to the engine. Since tube seals do leak it rarely causes engine damage.
    – MJH
    Jun 6, 2022 at 14:41
  • Guys, key question: why is the dipstick ejecting oil??? That's not normal engine behavior. A problem with a cylinder seal absolutely could be letting blasts of combustion products into the engine's galleries, causing overpressure there beyond what the PCV can handle, which would indeed lift the dipstick out of the tube and blast oily "air" out of it. So +1... unfortunately it would also mean a cylinder head or worse for OP. Jun 6, 2022 at 17:04
