2006 Ford Mustang - Ok so I've replaced the compressor clutch and accumulator. Every time the ac starts to blow cold the cooling fans turn on at the radiator and I can hear a click and the cooling system to ac turns off, starts to blow warm air. Almost everything is new and not sure what issue could be.
1Welcome to Motor Vehicle Maintenance & Repair! How did you ensure you have the proper amount of refrigerant in the system? Did you do the repair or did you have a shop do it for you? If you did it, did you draw a vacuum on the system prior to putting refrigerant back in?– Pᴀᴜʟsᴛᴇʀ2 ♦May 28, 2022 at 19:22
1 Answer
Based on your description either you do not have enough refrigerant in your AC system, intermittent failing relay for your compressor or your AC pressure sensor is faulty.
