I have a 2017 Subaru WRX and it’s making like a fluttering sound At idle but as soon as I push on the clutch it goes away and then when I’m driving the sound comes back. I’m not sure what it could be this is my first car that I’m working on and I don’t know much and I need help identifying the problem
Welcome to Motor Vehicle Maintenance & Repair! You say the noise goes away when you push on the clutch pedal. How much force does it take for the noise to go away? If you just push the clutch pedal in enough to take up the slack, does the noise go away? Or is it when the pedal is all the way to the floor?– Pᴀᴜʟsᴛᴇʀ2 ♦May 26, 2022 at 10:06
Sounds like a possible clutch or clutch mechanism issue. How many miles on the car? What kind of driving do you do?– jwh20May 26, 2022 at 13:28
1 Answer
It could be the clutch thrust bearing .Probably not an expensive part .I have not worked on subaru but somebody should be able to estimate labour which is bound to exceed the parts .
